Discussion topic: Router keeps disconnecting and reconnecting devices
This message was authored by: Justin91
We are seeing very intermittent WiFi, and keep getting disconnected on our phones/laptops. After a minute or two, the devices then reconnect.
the internet speeds also vary from 135mbps down to 60mbps when it is working.
Re: Router keeps disconnecting and reconnecting devices
@Justin91 to determine where the fault lie what do tge leds onnthe hub tell you? See https://www.sky.com/help/articles/hub-lights-explained-start which tells youbwhat the do.
Avatar for Justin91
Thanks @Chrisee . When the devices are disconnected, the router still shows a solid white line. The guide you shared (thank you for that) says that if the router is showing a solid white light then there are no issues. I've also done the diagnostics in the My Sky app, which shows that the WiFi and broadband are both green.
