Discussion topic: Router issues
This message was authored by: JJTJ17
Router issues
Hi,
two questions please:
1. How do you check what devices are connected to your router
2. how do you add an inverter dongle (from my solar panel set up) to be able to view what the app
TIA
Re: Router issues
Hi @JJTJ17
Depending on which router you have you can typically view connected devices in the My Sky app under your router management settings. If you have an older router you would have to login to its web interface at 192.168.0.1
As for your inverter dongle, you'd need to speak the manufacturer on how to connect it to a broadband router.
I am NOT a Sky Employee
