Discussion topic: Router issue no internet light
This message was authored by: 55alan
No internet light on router
alexa not working either
Re: Router issue no internet light
@55alan
So presumably no internet currently.
If you haven’t done it already use this link to check to see if there are any broadband problems or outages nearby.
This should determine if there's an identified fault affecting multiple households.
