Discussion topic: Router has no lights on
This message was authored by: Mooly
Sky router has no lights on. Have done a hard reset with no joy. Have checked all the connections.
Re: Router has no lights on
@Mooly   First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
@Mooly
If the same happens when you plug the router into a different plug then it might be that is has died so give Sky a call about this.
