Discussion topic: Router dropping signal
Message posted on
22 Jul 2025
08:34 AM
- last edited:
22 Jul 2025
01:56 PM
by
Nimbob
Broadband router keep dropping signal, starting from saturday afternoon and on this morning doesn't work at all.
Moderator notes: Edited title to remove PI
Message posted on 22 Jul 2025 09:05 AM
Re: 21 longrow/lowerhouse
@Ionut9 Can you please run the service checker, this can be done either via the Sky app on mobile data or use the link below.
https://www.sky.com/help/diagnostics/sky-broadband-diagnostic/sky-broadband-diagnostic
If it finds an external fault it should enable you to book an engineer.
After the service checker completes and if it comes back green all good can you click on broadband to run an updated test please. If you get amber or red please follow the on screen instructions.
