1
This discussion topic has been answered Discussion topic: Router box not workng
This message was authored by: Rich192
Can not get wifi the router box just has 2 green lights and orange in the middle.  Tried turning it off and back on. Still the same.  The router box is over 9years old
Re: Router box not workng
@Rich192
@Rich192
