Discussion topic: Router and q box connection
This message was authored by: 1cjjrv2
Message posted on 03 Jun 2026 03:24 PM
Just had new fibre and new router fitted, but it is not connecting to the Q box
Find out more
Message posted on 03 Jun 2026 04:19 PM
Re: Router and q box connection
If you now have a white Max Hub, you need to reset the network connection on the Q box and then choose the setup option which isn't for Sky Broadband.
