Discussion topic: Router Wifi Max Power Cable
This message was authored by: Ruthyp123
Does anyone know if I can use any power cable with the router? The cable is just a bit short to reach the shelf I want to put the router on so I can get an extension cable but might be easier and cleaner just to plug a generic usb c adaptor and cable in (which I already have). Would this work?
Re: Router Wifi Max Power Cable
@Ruthyp123 you can power a Sky Max hub over a USB C cable my own hub runs like that.
