Discussion topic: Ps5 won't connect to WiFi and videos won't load
This message was authored by: Theo_24
The ps5 wo t connect to the WiFi
Re: Ps5 won't connect to WiFi and videos won't load
@Theo_24 if other devices are connecting in the same area the issue will becwith the PS5 see here for help https://www.playstation.com/en-gb/support/connectivity/internet-connect-playstation/
If however the issue is insufficent wifi signal near the PS5 you will have to either improve thecwifi signal or better use an alternative type of network connection. Poorwifi is the main cause of lousy game play ideally you woukd run an ethernet cable frim the hub tomthe console or failing thst think about buying a powerline networking kit which usesctge mains wiring to carrybthe data.
