15
Discussion topic: Router Replacement Possible? bad wifi
MonkeyinThought
This message was authored by MonkeyinThought This message was authored by: MonkeyinThought
Re: Router Replacement Possible? bad wifi
@cookiemonsteruk
hi i have since bought the asus ax82 u but it seems like i ve done something wrong.... i ve attack the asus to the sky hub via LAN trying some steps i fummbered through and on the Asus menu i set it up as an Access point i m not sure i did the right thing.
ive lost all ability to acess the Asus menu and it just sends me to the sky hub menu.
the only wifi i address i can see is that of the sky hub even though i did setup one on my asus router. ( where it went i dunno?)
my Wifi was working really strangely i tried disabling my sky wifi but then i couldn't see any wifi network ,so i turned off and unplugged the asus router ... i tried to hard reseton the asus router but that didn't work. ....
1 Question should i have set the mode to wireless mode instead ?
