13
This discussion topic has been answered Discussion topic: Router Problem.
This message was authored by: KazMac2
Router Problem.
So this is my problem. Customer service told me to get a new phone connection to go in the Router. I did, it's the same as the old one I already had. It just doesn't fit in this space. Please can anyone explain as I only went live on Friday and still can't use my landline 🤨😢IMG_4484.jpegIMG_4485.jpegIMG_4486.jpeg
Re: Router Problem.
@KazMac2
The voice connection is the BT jack socket marked UK with a phone symbol.  The purple RJ11 is for copper broadband and cannot connect to a telephone handset.
This message was authored by: FLC
Re: Router Problem.
What's the back story, why were you told to get a new cable?
The cable you've pictured is an RJ11 DSL cable rather than a phone cable. I'm not aware of any UK phones that don't have the required BT connector, or at least an adapter from RJ1 to BT. So what phone do you have & where was it plugged in previously? I'd have thought it was plugged into a BT socket & you just needed to remove that & plug it into the Hub.
Re: Router Problem.
@KazMac2
Avatar for KazMac2
Level 2 icon
Re: Router Problem.
So what are you saying? I've got Fibre Broadband so have the new VOIP calls, which I know all about. The Customer Service woman told me to plug it in the one marked UK phone 📞, which doesn't fit. That's what I keep saying.
Avatar for KazMac2
Level 2 icon
Re: Router Problem.
I just unplugged the cable out of the back of my old Vodafone Router. I didn't need to unplug it out of the Openreach socket on the wall. So all I needed to do is just plug it into my new Sky Hub or Router. Like I've been saying, it different than the Vodafone one and it doesn't fit🧐🤨
Re: Router Problem.
Ah, so you already had VOIP with Vodafone.
So presumably you replaced the original phone cable when Vodafone was installed, Do you no longer have that?
Re: Router Problem.
Or possibly your phone cable originally had one of these:
Re: Router Problem.
Not being able to edit is a pain.
@KazMac2
It's far mor elikely that when you first installed Vodafone that you added the opposite adapter to your phone cable. This is borne out here:
So all you should need to do is remove that adapter & plug the BT plug into the Sky router.
This message was authored by: AndreaHunter
Re: Router Problem.
Can you send me a router as mine is cutting out and really slow
Re: Router Problem.
@AndreaHunter you are not talking to Sky by posting in the forum so nothing will happen to your request. Sky will replace a faulty hub if you call them. However cutting out and running slowly sounds more like a line issue or poor wifi neither of which will be cured by a new hub.
This message was authored by: Carol511
Re: Router Problem.
The connection box which was stuck to the wall keeps failing off. It is causing interference to the point I can't watch my TV. The wire is dangling but the box will not stay on the wall
This message was authored by: loverboi
Re: Router Problem.
@Carol511hi you will have to call sky then they can contact openreach to fix your master socket  🙂
This message was authored by: Geoff106
Re: Router Problem.
can you check my router
Re: Router Problem.
@Geoff106 Sky can do that, you need to call them for it to be done!
