Discussion topic: Router Issues
This message was authored by: Gincap
Router Issues
Not impressed 😟
Swapped to Sky from EE just recently as contract was up. All fine initially however WiFi around the home much weaker with Sky than EE. Now daily I'm having to reboot the router for WiFi to work, broadband fine, Ethernet connections fine.
Called Sky the guy in India 'I assume' had no idea what I was on about and kept going on about testing the line and Openreach. Nearly 30 minutes in and he still couldn't grasp that it was the router failing to pump out a WiFi signal unless it was rebooted. I just gave up on the call going around in circles.
Not impressed will do my best to cancel and switch back to EE ASAP!
Re: Router Issues
@Gincap Sky do sell a package called WiFi Max that can provide upnto 3 extender pods shich should help. See https://www.sky.com/help/articles/sky-wifi-max Sky often discount that bundle somits worth asking.
Avatar for Gincap
Level 5 icon
Re: Router Issues
Appreciate that but not sure I should be paying additionally when the router itself is not functioning correctly.
I've emailed Sky phone service is now unusable since the closing of UK call centre support. Will get out of the contract and switch back to EE.
This message was authored by: Bob224
Re: Router Issues
A message on my tv screen since last Sunday saying that I don't have Internet connection.  I have followed the instructions on my tv screen with no success. Can you please help?
Re: Router Issues
White Sky Max Hub by any chance?
It isn't a patch on the EE/BT kit or the FRITZ!Box/eero stuff supplied by Zen and others sadly. You can always add the WiFi Max add-on but unbelievably, whilst the hub is WiFi 6, the pods are WiFi 5... 😱
I assume the WiFi 7 Gigafast+ Hub is half decent, but only available on a CityFibre connection.
Sky Q | Sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam
Re: Router Issues
Hopefully a moderator will pick this up and move your request to it's own thread.
Avatar for Gincap
Level 5 icon
Re: Router Issues
@stereohaven
It's either broken or useless.
The call centre which used to be one of the shining lights of Sky has been decimated under Comcast the training overseas is non existent.
Re: Router Issues
Oh I don't know, they seem very well trained at trying to sell me more stuff! 🤣
This message was authored by: Me134
Re: Router Issues
I had a quick look and the Gigafast+ hub apparently is "more like a glorified WiFi 6E hub with firmly locked down firmware, frequently booting WiFi devices off the hub". Sounds familiar?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access with MLO enabled, main Deco hardwired to Max hub
