Discussion topic: Room 1
Message posted on 11 Nov 2025 06:14 PM
Room 1
Connection in room 1 is bad
Message posted on 11 Nov 2025 06:35 PM
Re: Room 1
@Eva+grace Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
