Discussion topic: No wi fi and no dialling tone on my landline phone
Message posted on 11 Nov 2025 05:53 PM
My wi fi sudeenly
stipped working and I checked my landline phone and there was no dialing tone. I can't see any issues in my area on sky service checker and it says when I ran a check on here for my broadband and wi fi it found no issues!? What do I do?
Message posted on 11 Nov 2025 06:08 PM
Re: No wi fi and no dialling tone on my landline phone
@elizabeth+123
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it takes a little while to update so perhaps try it again later).
