Discussion topic: Ring doorbells
This message was authored by: chococub
Ring doorbells
Can I connect a ring doorbell as I have Sky Stream? Will it run on 5ghz as I don't know how to split the signal to 2.4ghz. Can  it work with 5ghz? Thankyou
Re: Ring doorbells
Sky Stream is a TV service and doesn't have any smart home functionality.
I think this might be more of a Sky Broadband query. Could you confirm please? Maybe a mod could move this so you get on the right board.
This message was authored by: Ellie_TV
Re: Ring doorbells
Ring doorbells have nothing to do with Sky Stream.
You need to check with your broadband provider or the manufacturer of your router to find out how to split the WiFi channels.
Re: Ring doorbells
Assume you have Sky broadband?
If so which hub do you have, in the pictures shown here?
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
