Discussion topic: Ring doorbell
This message was authored by: Ringdoorbell
Ring doorbell
I have had Sky broadband installed again since 24 July and my ring doorbell continuously goes off line and doesn't record.  It is the only device I have issues with.  It is battery operated and the battery is good.   I previously had Sky so it's definitely the new connection as I didn't have issues before.  I need someone to check please as not happy
Re: Ring doorbell
No one is going to check a third party device for you I'm afraid.
However, there is a lot of help from Ring themselves for troubleshooting Wifi issues here: https://ring.com/gb/en/support/categories/wifi?page=1
I have a Ring Doorbell and Outdoor Cam and had to buy a Ring Chime Pro in the end that extend the connection so I got a strong RSSI from both devices. YMMV.
sky Q 2 TB | sky Q Mini | sky Mobile | EE Full Works FTTC | LG B6 OLED | SONOS Beam 2
