3
This discussion topic has been answered Discussion topic: Ring doorbell will not connect to Sky Max Router
This message was authored by: Colin_Cooper
Tried turning 5ghz off but will not connect
Re: Ring doorbell will not connect to Sky Max Router
@Colin_Cooper unless you have an ancient Ring doorbell there is no nedd to disable the 5GHz band thry msy only use the 2.4GHz band but link to dualband SSIDs. Couple of ideas first try connecting the doorbell closer to the hub and move it to its final lcation once connected. If that doesnt work reset the unit see https://ring.com/gb/en/support/articles/lc4kn/reset-or-power-cycle-your-ring-device?srsltid=AfmBOor5...
This message was authored by: Jc27a
I'm having the same problem since my router was changed to the white max hub , I had no problems previous to this! I've tried everything & it still is problematic! Trying to contact sky is a nightmare!
Avatar for Colin_Cooper
Thanks to Chrissi my Ring doorbell is now working. It was the advice and instruction to reset the doorbell itself that clinched it. Thanks to everyone that contributed.
