Discussion topic: Ridiculously terrible WiFi for MONTHS
This message was authored by: Adi_GaGa
Your WiFi is the worst its ever been over the last few months, what on earth is going on, as it's becoming ridiculous have some 4g on my phone, along with your WiFi (when it's available) that I pay for also!! Do I need to switch to a new broadband network that is more reliable and stronger in my local area?
Re: Ridiculously terrible WiFi for MONTHS
@Adi_GaGa
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
