Discussion topic: Hub has no internet light
This message was authored by: NickyW888
Service check says everything is good, but power and WiFi lights are green but internet has no light and voice is orange. Been through the hub reset twice, no change.
Re: Hub has no internet light
@NickyW888
See further down about the hub lights.
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
