Discussion topic: Restore From Backup Replacement Hub
This message was authored by: Aleksandrorlov
I have backed up my current sky SR203, I am being sent a replacement
Will the new hub accept the backup file from my old hub?
I would hope so as it has all my assigned UPS etc
Would like to think so and make my life easier.
Meerkat
Avatar for Aleksandrorlov
Level 2 icon
Re: Restore From Backup Replacement Hub
IPs, not UPS
Meerkat
@Aleksandrorlov
Yes it should accept the backup file but if you are getting a new hub because of an issue you are experiencing then its probably not a good idea to restore the new hub from a backup of your old one as you may carry over the problem.
I am NOT a Sky Employee
