Discussion topic: Replacing Sky Router completely
This message was authored by: ape72
I have Sky fibre broadband and am currently using the SR203 hub. I would like to be able to completely replace Sky hub with something else that would give me greater flexibility and customisation. I was thinking of the TP-Link AX3000. Does anyone know if that could replace the Sky hub? URL - https://www.bing.com/ck/a?!&&p=dbcdf9526be887f4JmltdHM9MTcyNjAxMjgwMCZpZ3VpZD0zNmZlMDA3My0yNDIwLTY1M... .
Re: Replacing Sky Router completely
@ape72
Do you have fttp or fttp
In thdd uk that may work by authenticating via dhcpv6 prefix delegation and not by the usual client identifier option 61 and 80% of exchange support prefix delegation
Avatar for ape72
How would I find out? Is it on one of the Sky hub settings screens?
@ape72
Theres no way of knowing unfortunately which exchanges are compatible with dhcpv6 prefix delegation
However all asus rt ax wifi 6 routers are compatible with client identifier option 61 and prefix delegation
@ape72
Again what connection do you have at the minute?
If you have superfast vdsl2 fttc then you'd need to factor in a vdsl2 modem bridge
