Discussion topic: Replacement WiFi router
This message was authored by: Grandpa+Jake
I need a replacement wifi router that has 3 Ethernet ports. Anyone know how I can order one of these from Sky as there’s nothing in the website? Thank you in advance.
This message was authored by: Doc5907
Re: Replacement WiFi router
@Grandpa+Jake
If its replacing an existing Sky router you will need to call Sky to arrange this.
Sky Q 1TB UHD
LG TV
Sky Mobile
@Grandpa+Jake What hub do you have just now take a look at the link, but if you do have the sky Q that i think you are talking about then by Dec 2025 is is due to be changed out but sky are controlling the changeover currently and it's FREE.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Avatar for Grandpa+Jake
Ok.  Thanks:  I can't wait that long unfortunately as I need more Ethernet ports now so I can set up an emergency alarm system for my old Mum - it's her router that needs the upgrade.
looks like I'll need to call Sky - wish me luck!
@Grandpa+Jake Here is the link below, try it and see if it get's you a replacement.
www.sky.com/skyhuboptions
Thank you.  I will have a go!
