3
This discussion topic has been answered Discussion topic: Replace Sky Router
This message was authored by: Tomc1987
Replace Sky Router
I need a replacement router as it has been dropping connection 10+ times in the last fortnight. We have had it for quite a while... maybe even 10+ years?
Re: Replace Sky Router
@Tomc1987
Does this link work for you:
https://sky.com/skyhuboptions
@Tomc1987
If you've had it that long it's probably no longer receiving security updates in which case you should have had an email in the last 18 months to replace it free of charge. My Sky Q hub was replaced in February 2025.
You will need to contact Sky when the lines reopen and discuss your options.
@Tomc1987
Avatar for Tomc1987
Amazing - thank you. This has worked
