Discussion topic: Remove broadband shield
This message was authored by: AmosTay83
Hello I've tried numerous times via different ways to remove the broadband shield on my broadband. I am 18+ household. Please remove
Re: Remove broadband shield
@AmosTay83 Sky cannot directly do that for you. You should be able to  control the Shield sssuming you are the sccount holder and sre using the corre ct Sky id. If you are certain you are call Sky as thry need to check your id permissions.
More here https://www.sky.com/help/articles/sky-broadband-shield-start
