Discussion topic: Broadbank network speed
This message was authored by: ThabaniZhou
I'm having problems with my broadband internet is tripping too much when streaming football and watching series
Re: Broadbank network speed
@ThabaniZhou if your issue is the spedd of your Broadband connection log into the My Sky app or website and run the service checker which will,show the last daily test result if the spedd is down the app should offer help to resplvecthe issue.
If, as is commonly the case, the spedd is ok then your issue is with the WiFi signal between the hub and your devices.Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Your choice.is to either buy Sky's add-on WiFi Max bundle which can supply up to 3 extenders see https://www.sky.com/help/articles/sky-wifi-max or buy your own wifi system and use that instead of the Sky hub's WiFi.
