Discussion topic: Regular broadband disconnect
This message was authored by: Cindy1972
I work from home and regularly my broadband drops during the day. The internet light on my router is amber. Often it is out for approx 30 mins and may come on and off intermittently through that day. This is not sustainable when I work from home and am on zoom calls all day that rely on internet connection. Can you help?
Re: Regular broadband disconnect
@Cindy1972
You haven’t contacted Sky by posting here. This is a customer ▶️ customer discussion forum where we try to help other customers.
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
