Discussion topic: Connection issues
Message posted on 08 Jan 2026 11:32 AM
Connection issues
Hi! I have big issues with my wi fi connection. Since I switched the provider I had big issues with my wi fi
Message posted on 08 Jan 2026 12:26 PM
Re: Connection issues
@MihaelaFira
See further down for guidance on hub lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
Message posted on 08 Jan 2026 12:28 PM
@MihaelaFira The Forum is not sky customer service but we are here to try to help, that is a two way street and does take participation on your side, if it's just not your forte then calling sky by dialing 150 on your landline will get you to speak to someone. Also take a look at this help below!
