Discussion topic: Red los light
This message was authored by: VJ1607
Red los light
My internet is not working and there is a red light on the route box
I have rebooted the router but we still have no internet
please advise urgently
Re: Red los light
@VJ1607 You will never get ANYTHING as long as you have the red LOS lit on the ONT. It is impossible to get Broadband Internet connection with that fault light!
Avatar for VJ1607
Re: Red los light
I have done a reboot but still the same.
reported to sky- any suggestion?
Re: Red los light
@VJ1607 If you have the same condition 8am tomorrow then yes report it, if an Engineer is working somewhere on the Fibre network and had to down the connection if that is the case it will start up again when they are finished all by itself. So best just leave it alone!
