Discussion topic: Red light
Message posted on 08 Jul 2026 04:15 PM
Red light
Message posted on 08 Jul 2026 04:21 PM
Re: Red light
@Buster2006x
Use this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky accept it's fine for customers working from home to use it, they won’t receive additional or quicker support.
