Discussion topic: Red light
Message posted on 31 Dec 2025 06:08 PM
Red light
My sky box just has one red light on it. I've followed all advice online like turning it off and waiting and checking all loose cables but still nothing
Message posted on 31 Dec 2025 06:50 PM
Re: Red light
See further down about the hub lights.
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
