Discussion topic: Red light on openreach box los
Message posted on 17 Feb 2026 11:08 AM
Red on Los - have checked all wires and they are fine. Did do a broadband test on my phone via sky app. Results are saying all looks good. There is no internet.
Message posted on 17 Feb 2026 11:18 AM
Re: Red light on openreach box los
@Kanzul
