Discussion topic: Red light on no connection
Message posted on 09 Dec 2025 11:00 AM
I cannot connect to the internet there is a red light on And have checked everything
Message posted on 09 Dec 2025 11:03 AM
Re: Red light on no connection
Still cannot connect to the internet
Message posted on 09 Dec 2025 11:06 AM
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
