Discussion topic: ❌ Red PON = still a problem
This message was authored by: Gintare91
What’s Wrong?
From the Openreach ONT box:
  • The PON light is red — ❌ This usually means there’s no fibre connection or a signal issue.
  • The LOS/Alarm light is off, which is good.
  • The Power light is on, which is also good.
From the Sky router:
  • The Internet light is amber/orange — ❌ this means it’s not connected to the internet.
Re: ❌ Red PON = still a problem
@Gintare91
Try running the line test here to see if any faults are found:
If this is of no help give Sky a call to report it to them.
This message was authored by: Deb3000
That's most likely to be that there is a physical connection, (i.e. the fibre is lit), but there is a logical connection problem, (i.e. an account problem, authentication failure etc.)
(As an after-thought, if this is a new install, it's most likely a serial number mismatch between the ONT and what the headend has on record).
