15
This discussion topic has been answered Discussion topic: Red PON light
This message was authored by: Gladrags2225
Red PON light
New installation of full fibre broadband today. Worked for one hour. Then solid red PON light on Openreach box and no broadband. All sky checks say everything is fine. Please help.
Avatar for Gladrags2225
This message was authored by: Gladrags2225 Answer
Re: Red PON light
Red PON light means there is a break in the optical fibre cable.
In my case, in the outside grey box, the splice between the internal and external fibre optic cables had separated and hence the problem. Was a 5 minute fix for the open reach engineer. Tho he did need a specialist splicing machine.
Re: Red PON light
@Gladrags2225  Are you just running the service checker or are you clicking also on the broadband button to run a updated test?
Re: Red PON light
Thanks Highlinder
spoken to sky, and apparently red PON light is an Openreach issue. Fingers crossed they'll fix it tomorrow with an engineer visit.
Re: Red PON light
This message was authored by: Speccy140810
Re: Red PON light
Hi how do I report the Pon light? Is it through sky or openreach?
Re: Red PON light
I reported a technical problem thru sky. Engineer came next day. Phoned sky, not sure which number.
This message was authored by: Primescape
Re: Red PON light
Brand new service should have gone active yesterday but red light on router despite rebooting etc. Sky said they checked the line before we proceeded with the contract. My own check says all is well but it obviously isn't. You refer to two checks. What are they and what's the difference please?
Re: Red PON light
@Primescape if you have full fibre then check the ONT  unit on the wall this thread discusses the issue with a LOS red light on that which means the fibre network is nit working. This can happen after an ibstall if the weld done by thecengineer with the external fibre cable fails. Call Sky are report the issue.
Red light in the hub also indicates the hub has lost connection again unless the service checker in the My Sky app run over a mobile connection reports that Sky arexaware of the fault call them to report it.
This message was authored by: apcth1
Re: Red PON light
Mine has gone after 1 day. 1 day!!!
Seriously unimpressed.
Re: Red PON light
@apcth1 The ONT or the Sky Router?
This message was authored by: Bungle79
Re: Red PON light
Watching 👀 TV then sky **bleep** on screen then everything blocked 🚫  nothing works
Re: Red PON light
  • Yes
Re: Red PON light
@Bungle79 if the ONT unit iin your home showing a red LOS light which is the subject of this thred then all online services stop LOS = Loss Of Signal.
Given the timing of your post it could simply be Openreach taking kit off line for essential maintenance work if so the service will be back by this morning. If it isnt and the Service Checker in the My Sky doesnt indicate Sky know of an issue affecting your line give them a call.
This message was authored by: Sammie67
Re: Red PON light
I've been without internet, WiFi and TV /sky glass all evening. BT engineer can't come until Monday afternoon, it's Friday today. Will I be able to claim a refund for loss of service?
Re: Red PON light
