Discussion topic: Red LOS light no PON light
This message was authored by: Josh04
Come 8Pm tonight my whole internet stopped working, checked the app it says everything is running fine and my devices are connected. Come to check my router a few minutes later I've got a Red LOS light and no PON light, I've tried restarting everything but two hours later nothing.
Re: Red LOS light no PON light
@Josh04
If your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
