Discussion topic: Poor signal
This message was authored by: Debass
Message posted on 10 Apr 2026 09:52 PM
Poor signal
My flat is small and the signal from the router is always poor to get to the tv it's insane.
Find out more
Message posted on 10 Apr 2026 09:57 PM
Re: Poor signal
Try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will supply up to 3 pods as you can read about here:
Select "No, I still need help" at the bottom on the above link.
Message posted on 10 Apr 2026 10:14 PM
Re: Poor signal
Thanks Caesarome I've already tried it all and didn't help.
