11
This discussion topic has been answered Discussion topic: Received Message "Sent the wrong hub"?
This message was authored by: ChilliDog
Hi, I recently joined Sky and received a hub package this week. My activation date is 21st April. However, I got another message saying the wrong hub was sent by mistake and that a replacement is on the way. I haven’t received the new one yet. Is there any way to track the package or get an update? When I tried calling, I only got an automated response and was directed to a web link.
This message was authored by: Jynxy Answer
Re: Received Message "Sent the wrong hub"?
If this is superfast then you will have the correct router.
Sky Superuser - If i have helped you please mark as solution to help others. Thanks
1x Sky Q Silver - 1x Sky Wifi Max Hub - SKY Fibre Ultrafast.
This message was authored by: peter-marlow+1966
If you have the my sky app it may be worth  logging on  there and see if you can track the order
P c marlow
@ChilliDog
Does anything appear here for you:
https://www.sky.com/ordertracking
Avatar for ChilliDog
Hi @caesarome ,  it only shows that the previous package (the wrong one) was delivered. There's no information about the new hub.
What hub was you sent? this could have been an automated system error and that you may have been sent the correct one.
Hi @Jynxy , I received a black one, Model: SR203.
What Broadband did you order? this will work with most connections,
It is called "Sky Broadband Superfast" on the order page. The message I received shown as Sky Hub 4.2.
I see. Thank you so much for your help.
This message was authored by: Wally3
We have received exactly the same text sent 17 April. Nothing received and no further communication. Did you get issue resolved?
message was
Yes, I received another package last week, and they asked me to return the original one.
