Discussion topic: Re: No WiFi
This message was authored by: Michelle6361
Re: No WiFi
I have no wifi
Re: No WiFi
@Michelle6361
The first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
