Discussion topic: RING video images
This message was authored by: Ironside2
RING video images
Front door video bell and rear camera images are breaking up in the last two weeks but were OK before. I have changed nothing at all . I suspect Sky wifi speed slowing down. Can't think of anything else.
Re: RING video images
Hi @Ironside2
It is possible that the WiFi environment around you has changed which is causing the range to be lower or the speed at those far points where your cameras are to be lower.
Please post your router stats
https://helpforum.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/td-p/2855717/jump...
I am NOT a Sky Employee
Avatar for Ironside2
@jamesn123 How do I send you my router stats when I am warned by Sky not to send personal details or Sky Account info which is would be avialble to the public?
@Ironside2
The link tells you how to obtain your Sky router stats, once you have got to them take a screenshot and then post it as an image on the forum. Dont worry there is zero personal or identifiable information contained within your router stats.
@Ironside2 the connection stats are accessed in a window that openns from a link at the bottom right on that page.
Status of your broadband and WiFi network
Broadband Connected
WiFi Enabled
WiFi Network Name (SSID) SKYQULJG
WiFi Network Visible Yes
Current WiFi Channel 11 (2.4 GHz), 36 (5 GHz)
WiFi Encryption WPA2-PSK
Devices connected to your home network
Device Name MAC Address UNKNOWN 02:0f:b5:d0:51:32 UNKNOWN 5c:e9:31:5a:a0:27 RingStickUpCam-f6 02:0f:b5:41:28:f6 UNKNOWN 02:0f:b5:7f:cb:68 ESP_32057C 70:03:9f:32:05:7c ESP_263884 70:03:9f:26:38:84 UNKNOWN 64:ff:0a:ea:07:d6 UNKNOWN 38:f7:3d:49:db:03 SKY+HD 78:3e:53:7f:97:62 SKY+HD 78:3e:53:5c:94:7a UNKNOWN 3c:9e:c7:4a:a6:29
