Discussion topic: Public IP
This message was authored by andre95 This message was authored by: andre95
Public IP
Hi,
I have a sky router SR203 with a TP-Link mesh router connected via Ethernet.
I have been trying to set the VPN setting up on this but I can't get the public ip address to be visible from the sky router to the tp link router.
Does anyone know what I need to do to get this to work. I'm guessing it's port forwarding but I don't know anything network related and can't figure it out. What port etc and where do I set this in the sky router.
Re: Public IP
@andre95 it cannot be done as the Sky hub does not have a modem or bridge mode. Are you sure you need the public IP address to operate the VPN function?
andre95
Re: Public IP
Im not sure is the truth.
would it just need a port forward from my sky router to set up an open vpn?
Re: Public IP
Which VPN functionality are you attempting to set up?
Site-to-site VPN is different to running a VPN server for home network access from outside, for example.
Re: Public IP
@andre95
You need to port forward twice. On the Sky router forward the port from WAN to your TP-Link routers local IP. THen on the TP-Link router enable the VPN service
I am NOT a Sky Employee
