Discussion topic: Public IP Range
This message was authored by Denisjf This message was authored by: Denisjf
Public IP Range
Hi,
Is there a way to determine what the range of public ip addresses sky uses to assign to me?
I presume sky owns a block of ip addresses which are assigined dynamically
Re: Public IP Range
@Denisjf
There are commercial services which will read into the RIPE database, but these are likely to return too many results to be particularly useful.
For example:
https://ip-netblocks.whoisxmlapi.com
Putting 'Sky UK' in there hits a limit of 100 results, each for a different block.
Denisjf
Re: Public IP Range
@TimmyBGood thanks for your reply.
I tried entering my ip here and it gave me the following range
https://www.iana.org/whois?q=
213.0.0.0 - 213.255.255.255
Re: Public IP Range
@Denisjf given Sky have in excess of 6 million customers each of which if connected will have a unique IP4 public IP address you can expect a significant number of different blocks and sub-blocks.
Re: Public IP Range
@Denisjf
That's a Class A range containing some 16.7 million addresses: Sky doesn't own a Class A (I don't think any single ISP does) and it would be hugely wasteful if they did.
