Discussion topic: Ps5 wont connect
This message was authored by: MrsBut
Message posted on 16 Jul 2026 02:14 PM
Ps5 wont connect
Message on ps5 is 'cabt connect to netwrk the ps5 doesn't support ipv6 only networks, select a network that supports ipv4" We had full fibre installed yesterday and now cannot connect to ps5 which is vital
Find out more
Message posted on 16 Jul 2026 02:43 PM
Re: Ps5 wont connect
@MrsBut by default Sky offers both IP4 and IP6 through the hub so I suspect it is a confguration issue on the PS5.Check that you have not set a fixed IP4 address for your old ISP. Sky uses the address range 192.168.0.2 to 192.168.0.254.
