4
This discussion topic has been answered Discussion topic: Problems
This message was authored by: Ericbrown
Problems
I have had  Sky superfast 1 installed into my home   Since then I have no phone line , my laptop is very slow and I can't use my printer as it does not recognise anything. When I sign up for this no one explained  any issues I could have with this.
Avatar for Ericbrown
This message was authored by: Ericbrown Answer
Re: I have a black router and phone plug is in the back of the routerProblems
I have a black router and the phone plug is in the back of the router. The phone line is now working for some reason. I still cannot connect the Tv and laptop is slow and printer not working
Re: Problems
@Ericbrown  What colour of router do you have black or white? Where is your phone plugged in at the moment?
@Ericbrown  The TV you might have to factory reset it if you are trying to get it to work over Wi-Fi. The printer it also might need reset as it might hold the old memory if connected by Wi-Fi.
If the above does not work it might be worth trying to split the Wi-Fi bands, this can be reversed if it does not work, if you want to try this follow the directions in the link below.
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
How old is the laptop that you are trying to connect?
Re: Problems
I have a Samsung Tv and Connor find thr reset button. Also concerned doing this as I do not want to  completely mess things up. I have had several call today to try and resolve this and feel that someone should come out to eslove this problem as I did not have problem before I went fibre super fast connection. I know you are trying to help but either someone talk to me over the phone step by step instruction it becoming to much for me. I am 68 years old and all I want is what I am paying for
