Discussion topic: Problems with my tv connecting to wif
This message was authored by: Cdawson
The Internet isnt working on my TV
Re: Problems with my tv connecting to wif
@Cdawson Is everything else working ok connection wise to the sky Hub? Possible the sky help below may be off some good to you!
sky connecting devices
https://www.sky.com/help/articles/connect-devices-to-broadband-start
Avatar for Cdawson
Everything else is connecting to the WiFi with no problems. The TV goes in and out of connection all the time. I have checked with the TV company and there doesn't seem to be a fault with the TV it just says with the connection
@Cdawson It's the TV that connects to the sky Hub, if wireless wifi connected or Ethernet, also which sky Hub, white or black?
