Discussion topic: Problems with booster
This message was authored by: StuWat
We've had a booster for about a month know and it's been working fine.  Today, all the devices that connect to the booster has started to drop.  Unplug the booster and they all reconnect and work without issue.  Plug the booster in and they drop again.  We've tried moving the booster to 5 different locations in the house, have tried multiple times to reset the booster and reconnect the problem still occurs.  Any suggestions anyone?
Re: Problems with booster
@StuWat Sometimes equipment can go faulty even after a short time. Which specific booster do you have that is causing the issue, sounds like your devices are connecting to the router when the booster is switched off.
