08 Jul 2022 11:45 PM
I was trying to get to a website via home router on chrome or any browser
It failed to get to site but I could get site on phone OK.. Via mobile network
Not router network on phone
To cut a long story short when I changed dns to Google dns on laptop
All worked ok
Why would sky dns be out of date
How do i get it working with the website Google dns found no problem
I never thought of dns I thought it was router or browser issue
This simple issue caused me 4 hrs of fault finding
But we are having connection issues so this could be part of the problem
Any help appreciated
09 Jul 2022 06:47 AM
Assuming this isn't Sky's "Shield" parental filter causing problems, then I've had this issue before, where access to sites suddenly becomes quite sporadic for no clear reason. The solution that works for me is to turn off your router for a few short minutes, then turn it back on again.
09 Jul 2022 08:04 AM
Posted by a Superuser, not a Sky employee. Find out more@thinkingofmoving this can happen when a site changes hosting provider as that change has to replicate down the DNS chain as no one server knows every address it works on a heirarchy . Google's DNS is often faster at picking up changes especially on smaller sites than ISP's servers. If it could also be an issue with Broadband Shield so its worth checking your settings which default to age13 unless you change it..
Another possible cause is Sky has multiple machines providing DNS services and it has been known for the one you are connected to be faulty which is a pain but rebooting your hub by switching off the power for a few minutes can sort that as your new IP address is likely to be on a different gateway. DNS issues are quite common so perhaps should be further up your list if other services are working normally.
09 Jul 2022 08:17 AM
Change your routers DNS settings (in DHCP) to one you are happy is working well
09 Jul 2022 08:24 AM - last edited: 09 Jul 2022 08:43 AM
The DNS servers on Sky routers are fixed, the only real way to change these is to use a third-party router or even better firewall round-robin DNS to the different DNS infrastructures. But the DNS servers of Sky are quite reliable but not perfect, what is perfect! 😀
My own DNS servers snapshot...
