Discussion topic: Problems internet
This message was authored by: JuliaJulia11
Problems internet
Good afternoon my Wi-Fi doesn't work all day today. I restarted  it a few times and it doesn't help.
there are two green lights and one orange on the Wi-Fi box.
I would appreciate your help.
thank you.
Re: Problems internet
@JuliaJulia11
