Discussion topic: Internet issues
This message was authored by: Amy+Marshall+x
Internet issues
Good Afternoon,
My internet keeps dropping out and I work from home so it needs to be improved. I have been with you for 9 years now and it keeps getting worse and worse.
If this isn't sorted we will go elsewhere for our internet.
Kind Regards,
Amy Marshall
Re: Internet issues
@Amy+Marshall+x
It's pointless threatening to go elsewhere on here. You may not be aware but you haven’t contacted Sky by posting on here. This is a customer ▶️ customer discussion forum where we try to help other customers.
