Discussion topic: Problems connecting old printer to WiFi
This message was authored by: GerryMcM
I have an old HP Printer and cannot connect to the new SkyHub WiFi Have tried WPS , doesn't work
Re: Problems connecting old printer to WiFi
@GerryMcM if you have a white Sky hub change thecWiFi security setting from WPA3-T to WPA2 and try again Otherwise factory reset the printer and is possible updates its firmware by connecting to a. Devicecwith internetvaccess and a USB port. Aftervthst it should hopefully connect directly
