Discussion topic: Problem
Message posted on 11 Apr 2025 01:32 AM
Problem
No connection at all saying there's no problems when clearly there is
Message posted on 11 Apr 2025 01:35 AM
Re: Problem
Mine is the same, it's so annoying
Message posted on 11 Apr 2025 05:17 AM
Re: Problem
At that time of night it could be essential overnight maintenance taking place which is carried out then to minimise disruption as most customers are asleep.
If it hasn't come back on by about 0700 use the below link to check to see if there are any broadband problems or outages nearby
